OBLM supports notional pooling of accounts for cash concentration benefits. Under notional pooling, balances remain on participating accounts. The bank charges or credits interest on net balance of the pooled accounts thereby mitigating the cost of overdrafts on participant accounts.
Notional Pooling of is a mechanism for calculating interest on the combined credit and debit balances of accounts that a corporate parent chooses to cluster together, without actually transferring any funds. It is ideal for companies with decentralized organizations that want to allow some autonomy to their subsidiaries, including their control over bank accounts.
Pool participant accounts are aggregated for interest compensation purposes. Funds are not physically moved, but are notionally combined. There is no commingling of funds, and the integrity of the individual account position is maintained.
Notional Pooling can be combined within the framework of a global cash concentration structure to provide comprehensive overlay structures to meet even the most complex organization’s needs
Notional pooling can have multi-layered overlays like in country pools sweeping into regional pools which in turn sweep into global pools. This type of structure is provided to mirror the corporate’s regional treasury arrangements.
Once a company earns interest on the funds in a notional pooling account, interest income is usually allocated back to each of the accounts comprising the pool. For tax management reasons the corporate parent usually charges the subsidiaries participating in the pool for some cash concentration administration expenses related to management of the pool. This scenario works best if the corporate subsidiaries are located in high-tax regions where reduced reportable income will result in reduced taxes.
The main downside of notional pooling is that it is not allowed in some countries. It is difficult to find anything but a large multi-national bank that offers cross-currency notional pooling. Instead, it is most common to have a separate notional cash pool for each currency area.
Notional pooling is normally done within one branch so that the bank gets the right of offset on its balance sheet (from the regulators and clients). Else bank has to set aside capital to cover the gross pooled balances
The benefit of notional pooling can be listed as below:
Notional Pooling can take any of the following structures:
Interest on pool participants can be calculated in the following ways:
Interest is calculated at each participant account as per their balances with an applicable rate and debits and credits posted to the participants accordingly.
Next interest is calculated based on the pool balance at notional header in notional header currency.
The difference between the interest arrived at the pool level and the summation of interest arrived at the participant level is called the advantage interest (Z-I).
For Advantage method, we need to set the IC setup. Please follow the below steps:
You can invoke the ‘Interest Rule Setup’ page by clicking on the setup tab in application.
Rule ID
Specify a rule ID.
Rule Description
Specify a description for the rule.
Apply Interest on Account Opening Month
Check this box to apply the interest on the account opening month.
System Data Elements
Click '+' button to add system elements. Specify the system elements like DAYS, LMVD_CR_BAL and YEAR. You can select the system elements from the option list.
User Elements
Specify a user element.
Type
Select the type as “Rate” from the drop down list.
Get Latest
Select the option “Use Current” which is to be used as latest
Accruals Required
Check this box if accrual are required.
Book Flag
Select the book flag “Booked” from the drop down list.
Periodicity
Select the frequency “Daily” from the drop down list.
Days in a Month
Select “Actual” from the drop down list. The options are:
Days Year
Expression
Specify the expression for the formula
Condition
Specify the condition for the formula
LMVD_CR_BAL>0
Result
Specify the expected result
(LMVD_CR_BAL*RATE1*DAYS)/(YEAR*100)
You can invoke the ‘Interest Product Setup’ page by clicking on the setup tab in application
Product Code
Specify a product code for the new interest product
Product Description
Specify a description for the new interest product.
Product Group
Specify the product group under which the new product is based. You can select the product group from the option list. The list displays all the product groups maintained in the system
Product Group Description
The system displays the description for the selected product group.
Rule
Specify the rule to be associated with the interest product. You can select the rule from the option list. The list displays all the rules maintained in the system
Rule Description
The system displays the description for the selected rule.
Start Date
Specify the start date of liquidation.
End Date
Specify the date till which the interest product will be active.
UDE Currency
Select the UDE currency to be associated with the product from the drop down list. The options are: Account Currency, Local Currency
Currency
Select the currency from the option list. The list displays all the currencies maintained in the system
Main Interest Rate UDE
Specify the main interest rate UDE.You can select the interest rate from the option list. The list displays all the interest rate UDEs maintained in the system
Frequency
Select the frequency of accrual “Daily” from the drop down list.
Cycle
Select the cycle for the accrual “None” from the drop down list.
Payment Method
Select the payment method for interest accrual “Bearing” from the drop down list.
Calculation & Liquidation Frequency
Days
Specify the liquidation frequency as 1 for the Interest product being created.
Start From Account Opening
Check this box to start the calculation of liquidation from the start of account opening.
First Liquidation On
Specify the date for calculation of first liquidation.
Start Date
You can invoke the ‘Interest UDE Setup’ page by clicking on the setup tab in application
Product Code
Specify the product code. You can select the product code from the option list. The list displays all the product codes maintained in the system
Branch Code
Specify the branch code. You can select the branch code from the option list. The list displays all the branch codes maintained in the system
Currency Code
Specify the currency code. You can select the currency code from the option list. The list displays all the currency codes maintained in the system
Effective Date
Specify the date from which this will be effective
User Element
Specify the User Element what we have given in Interest Rule setup
User Element Value
Specify User Element Value.
Account Number
Specify the account number to be mapped. You can select the account number from the option list. The list displays all the account numbers maintained in the system.
Interest Product
Specify the interest product. You can select the interest products from the option list. The list displays all the interest products maintained in the system.
Interest to be initially calculated without taking the pooling arrangement into account and then a rebate is to be paid to the group
Bank arranges preferential interest rates for participating accounts without fully offsetting credit and debit balances. This option will be used in jurisdictions where full notional pooling is not permitted.
In this method dual interest rates are applied i.e. Balance of the account is segregated in to compensated and non compensated balances and interest rates applied accordingly
Compensated (Covered) and non compensated (residual) balances are arrived by the following logic
Compensated (Covered) and non compensated (residual) ratios are arrived
Credit |
Net Pool Position (NPP) > 0 |
Net Pool Position (NPP) < 0 |
Coverage Ratio (Compensated Balance) |
Min(Cumulative Credit,
Cumulative Debit)/ |
1 |
Residual Ratio (Non-Compensated Balance) |
1 - Coverage Ratio |
0 |
Debit |
1 |
Post arrival of the Compensated (Covered) and non compensated (residual) balances interest rate is applied using the following formula
For accounts in Credit balance (NPP>0 or NPP<0)
{[Credit Coverage Ratio * Account Balance] * Covered Credit Interest} +
{[Credit Residual Ratio * Account Balance] * Residual Credit Interest}
For accounts in Debit balance (NPP>0 or NPP<0)
{[Debit Coverage Ratio * Account Balance] * Covered Debit Interest} +
{[Debit Residual Ratio * Account Balance] * Residual Debit Interest}
For Optimization method, we need to set the IC product . Please follow the below steps:
Rule ID
Specify a rule ID.
Rule Description
Click '+' button to add system elements. Specify the system elements like DAYS, LMVD_CR_POOLBAL, LM_CONTRIBUTION_BAL, LM_CRCOV_RATIO, LM_CRRES_RATIO and YEAR. You can select the system elements from the option list.
User Elements
Specify a user elements as COVRATE and RESRATE.
Type
Get Latest
Accruals Required
Book Flag
Periodicity
Days in a Month
Days Year
Expression
Condition
1:-
Specify the condition for the formula as
LMVD_CR_POOLBAL>0
Result
Specify the expected result as (((LM_CONTRIBUTION_BAL*LM_CRCOV_RATIO*COVRATE*DAYS)/(YEAR*100))+((LM_CONTRIBUTION_BAL*LM_CRRES_RATIO*RESRATE*DAYS)/(YEAR*100)))
2:-
LMVD_DR_POOLBAL>0
Result
Specify the expected result as (((LM_CONTRIBUTION_BAL*LM_DRCOV_RATIO*COVRATE*DAYS)/(YEAR*100))+((LM_CONTRIBUTION_BAL*LM_DRRES_RATIO*RESRATE*DAYS)/(YEAR*100)))
Product Code
Product Description
Product Group
Rule
Rule Description
Start Date
End Date
UDE Currency
Currency
Frequency
Cycle
Payment Method
Days
Start Date
Product Code
Branch Code
Currency Code
Effective Date
User Element
User Element Value
Account Number
Interest Product
Specify the interest product. You can select the interest products from the option list. The list displays all the interest products maintained in the system.mization method, we need to set the IC product . Please follow the below steps:
Interest Enhancement method works by applying preferential pricing across a group of accounts on the basis of pre-determined criteria that are typically based on a net aggregate balance threshold.
For example, a company with multiple credit balances distributed across its various operating centers may find that individually these balances only qualify for the lowest interest-rate tier payable on credit balances. By contrast, under an interest-enhancement arrangement, the total of these balances is used to enhance the qualifying tier of the individual balances
The accounts participating in the enhancement pool will be attached with an enhancement rate card which has the interest slabs and their corresponding rates. These rates will be applied over and above the base interest rates (applied on to the accounts) to calculate and credit the enhancement rate
In some cases bank may offer premium interest rates in addition to the above (base rate + enhancement rate) for a balances in a specific currency in such cases one more rate card will be attached to that particular currency accounts and interest will be calculated on those accounts with rate as base rate + enhancement rate + premium rate
For Interest Enhancement method, we need to set the IC setup. Please follow the below steps:
Rule ID
Specify a rule ID.
Rule Description
Click '+' button to add system elements. Specify the system elements like DAYS, LMVD_CR_BAL, LM_IERATE and YEAR. You can select the system elements from the option list.
User Elements
Specify a user elements as RATE.
Type
Get Latest
Accruals Required
Book Flag
Periodicity
Days in a Month
Days Year
Expression
Condition
1 :- Specify the condition for the formula as
LMVD_CR_BAL>0
Result
Specify the expected result as ((LMVD_CR_BAL*RATE1*DAYS)/(YEAR*100))+((LMVD_CR_BAL*LM_IERATE*DAYS)/YEAR)
2:-Specify the condition for the formula as
LMVD_DR_BAL>0
Result
Specify the expected result as ((LMVD_DR_BAL*RATE1*DAYS)/(YEAR*100))+((LMVD_DR_BAL*LM_IERATE*DAYS)/YEAR)
Product Code
Product Description
Product Group
Rule
Rule Description
Start Date
End Date
UDE Currency
Currency
Frequency
Cycle
Payment Method
Days
Start Date
Product Code
Branch Code
Currency Code
Effective Date
User Element
User Element Value
Account Number
Interest Product
The interest calculated for notional pooling has to be distributed to the participant accounts. The different allocation models which are supported by LM are as below:
In this method, the interest\ advantage interest arrived is credited to one central account which can be one of the participant accounts or any other account
System will allow payment of this interest/charge to a particular/nominated account which can be done in two ways:
Here Credit interest is calculated on aggregated daily credit balances and Debit interest is calculated on aggregated daily debit balances. The Debit and credit interests are posted separately to the nominated accounts.
Here the net interest position is calculated on the net balance of the pool and paid or charged to the master account.
In this method, the interest\ advantage arrived is evenly distributed amongst the participant accounts
In this method the Interest reward is evenly spread across all accounts with positive balances.
In this method, pre-defined percentage of the interest\ advantage arrived is distributed amongst the participant accounts.
In this method, If the net pool position is positive, the interest/advantage interest arrived is distributed amongst the positive contributors in the ratio of their contribution (Both in Interest and Advantage models).
If the net pool position is negative the interest amount is distributed amongst the negative contributors in the ratio of their contribution (Interest model)
If the net pool position is negative, the advantage interest amount is distributed amongst the negative contributors in the ratio of their contribution. For example, the interest calculated at the account level is @10% but the interest calculated at pool level is @8% taking into consideration few positive account contributors (Advantage model)
In this method, if the new pool position is positive, the interest/advantage interest arrived is distributed amongst the negative contributors in the ratio of their contribution (Both in Interest and advantage models)
If the net pool position is negative, the interest amount is distributed amongst the positive contributors in the ratio of their contribution (Interest model)
If the net pool position is negative, the advantage interest amount is distributed amongst the positive contributors in the ratio of their contribution (Advantage model)
In this method, absolute balances of all accounts would be considered and interest would be shared proportionately to all accounts.
Interest reallocation is applicable only to central distribution model of interest allocation. The interest/ advantage interest credited to the central account which would be a treasury account is re-distributed amongst the participant accounts using any of the above discussed allocation models.
In allocation models the debit was to the Bank GL, In re-allocation model the debit will be to the central treasury.
Note
